1g BOV dodge garage mod
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
After doing this mod, my car drops to like 2-300 rpm and sometimes dies when coming to a stop from being in boost. The new port that you make with this mod is not connected to anywhere. Should I connect it somewhere? Will that help?
Yes.
DDG- Talon BOV mod for HIGH BOOST
DDG said:
If you did your job correctly this is how the valve should look like- now pressure from the upper intercooler line cannot reach the lower port in the BOV. Installed on the Daytona with the new port open to atmospheric pressure this valve has held without leaking at 30 psi! And the best part is if I want the BOV to be "quick releasing" again (that's the whole point of having that port in the base of the valve from the factory) its a simple matter of running a vacuum line from the turbochargers outlet nipple to the new port and viola'.
