1g block 2g head?
willnatale
53
Mar 15, 2012
west warwick, Rhode Island
i have a 1g block will a 2g head fit and if so what should i keep from the 1g i seen someone say the intake manifold what else if there is something
did not mean to click the thumb down icon
The head will fit yes, you might have to open up the head bolt holes to 12mm I think. The 6 bolt headstuds are like a mm bigger than 7 bolt headstuds. Most consider the 1g intake manifold to be a bit larger than a 2g manifold.
There are a lot of threads on this so I know you did not search the forum or read the rules either.
However, you will or rather should bore out the head stud holes 1mm larger to properly fit the larger studs and you'll need to use the 2g water pump, pipe, and t stat housing. You'll also want to do oil mods #1 and #2 which you can find in the articles section.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
