General 1G Bins
OverboostXS
144
Feb 11, 2003
Pittsburgh, Pennsylvania
I am using TunerPro Rt and I was wondering where I can locate the proper BINS. Links or any form of info would greatly be appreciated.
Did you try the yahoo dsm ecu group? I can't remember where I saw them but I thought it was there.
Nice avatar
GVR4592 said:
Nice avatar
Have the car running already? Using Speed Density, MAF mode, AFC mode? You do have all the settings programed in correct?
It is running on a stock ecu as we speak but i am piecing together the burning kit, Do I Just read my stock chip via The burner itself to get my parameters?
You can or you can get them from the files section of the Yahoo DSM-ECU group like GVR4592 suggested. Most of us used the E931 file as our starting point.
Steve
Well, what mods are you running? I'm not thinking you should have to "burn" a chip being that you can make changes via the tuner pro. Although depending on what your mods are, you may need a dsm chip. I personally found out today that the stock ecu can't be used with a stock ecu and MAFTpro. It just can't pull enough fuel out of it.
Other than that, most parameters can be set with the MAFTpro or Tuner pro. But I don't know your situation and if you're running it yet, etc.
Steve
I did look for DSM-ECU at yahoo groups but only came up with Haltech stuff. Which I still joined and was unable to find the info, I searched as well as looking through downloads.
You make changes then burn it to the chip! A DSM-Chip is just that, a modified program.
But you need to search for DSMECU it is there-
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
