1G Bad ECU?
natedogg814
Sep 30, 2005
Oil City, Pennsylvania
Car runs great until I hit operating temp or as hot as its gonna get. Basically after that if I even hit the gas nothing shows on the AF gauge.
Data logger shows all injectors and pretty much everything is working as is should. Car sputters and I pretty much can't go anywhere. If I shut the car off and turn it back on everything is back to normal for a little while then it starts the sputtering and stuff.
I recently replaced the O2 sensor, coolant temp sensor, fuel filter and put in another set of stock injectors. Here's my mods list, BR Stage 2 Shortblock, Rebuilt ported head, 14b, Skunk2 cam gears, BR boost controller, BR 3" turbo back, Magnaflow cat, Walbro 255, BR AFPR, ARP's, Fluidyne radiator, XTD Stage 3 Clutch.
Is it most likely my ECU causing problems or should I be checking other things? Let me know what ya think.
