1g AWD rewire with trunk battery
phantom_19
410
Oct 13, 2007
curacao, South America
Hi
I was reading FAQ on plymouthlaser.com how to rewire a fuel pump. Because i think mine is either bad or does not get sufficient power.
I set the FPR to 37 with the vacuum line plugged. Realtime it went to 35 psi, when i give gas the car stalls and the pressure one the gauge goes to 37-38 psi. So it dances around.
the car has been standing still for 2 years with that pump, but with gas in the car. these past 2 months we started the car, not driving. It has fresh gasoline.
So about that re-wire, Do i have to run any wires to the front of the car? Or do all the wires just stay in the back, because my battery is in the trunk.
Thank you
Power from the battery, ground from the chassis, power wire to relay and relay to pump.so no...
