aspekt9
- 344
- 4
- Dec 25, 2005
Boston,
Massachusetts
Okay, I just got a 92' Talon shell and I'm going to be doing some underbody work and removing the complete rear diff and suspension. Does someone have a picture of the underside of the car that can point out the jack stand points in each of the 4 corners? I'm going to raise it up on all 4's for a while. I took a look at the pinch welds where some people have suggested but it doesn't look like there's a whole lot of surface area and they appear to have bent in some locations from the previous owner.
Are there other spots that I can get this thing up? I noticed a semi flat area at each corner the front flat areas have two holes in them and in the rear there's one nickel sized hole on the flat area, are these good places to place it? Again, any pictures would be extremely helpful!
Thanks
Edit: I attached a picture for points on the front end, the blue square was the area I was referencing, the red circles are a previous user on the forum who was asking if those were good points.
Thanks
