1g Fuel Tank Removal Guide:
6 Large Nuts and 2 10mm Bolts.
Not a single issue at all.
Jack the rear of the car up and support it with jack stands. Pre-spray all hardware with WD40 (or your favorite penatrant) first. The 2 10 mm BOLTS that hold the shield on (1 on each side, toward the front) come in from the top and one is kinda a PITA to get to but a 10mm ratchet wrench got to them and worked great. The others are larger nuts on studs. Came right off with my impact, easily. You have the filler hose, filler hose vent, tank vent hose and the hanger assembly itself. Mine still had the weird style double wire type hose clamps. Dont bother even trying to loosen them, they will just twist up. Cut those off with diagonal cutters and replace with worm style clamps for your convenience. They will be on the filler hose, at the tank and the filler VENT hose (about 1" OD on the top of the tank, hidden from view), so have some worm clamps available. Take the hanger out first. Pump out any fuel you can then unhook the filler neck bottom clamp. As the tank comes down/out (its not really heavy if empty), you will have access to the filler vent and tank vent lines.
Thats it, at that time it should be on the ground/out of the car.
On a scale of 1-10, it was a 2
Marty
Marty
