1G A/C compressor on but idle low ISC valve not working compensation for A/C
Elpizer2
167
21
Jul 31, 2022
Miami, Florida
I have 12 volts on pin 7 so we are ok
Pin 65 send ground to activate A/C relay
However the ISC valve does not work.
I replaced it and no changes.
Does anyone know what could be bad in the ECU? I opened it and everything seems good, nothing burned or something
Ohm your ISC (lots of information on here), and look at these driver ICs in the ECU . These are what go if your ISC shorts out . They don't just go randomly
Capacitor leakage causing damage to the idle circuit in the ECU. Part of the idle circuit trace is directly underneath the front-most capacitor that is easily taken out by corrosion or an inexperienced technician replacing capacitors.
    • george bromwell
    • pma1123
    • Sdcryan1
