Resolved 1G 80A Alternator fuse keeps blowing?
ChiTownHussla
1,268
6
Nov 16, 2010
Chicago, Illinois
Does anyone have a picture on which terminals to use for the alternator? My 80 amp fuse keeps blowing. I know it's the alternator one too btw. I have a wire attached by a nut to the alternator itself with no washer or boot.
I need a reference as to how to fix this. Thanks and pics would be ideal for this.
Solution
There's what's essentially a 1/8" thick rubber/plastic washer under it between it and the alternator.
Ok. So I just have to back the wire off a bit and put a bit of rubber or what? I lost the stock rubber piece in the engine swap pprocess. What do you reccomend? From what i can tell, the wire connector is touching the alt. That's the problem I gather?
Lol cool. How did that turn out btw? And how does said wire on alt stay connected but not touch supposedly? I wanna pic LOL.
Solution
OK Ill buy that and try it. Ill update later today
Okay guys the rubber insularity was the problem. This is solved and marked as so. Thanks for the help guys. Hopefully someone eelse will need this and come across it. ;)
