Candymancan
- 0
- Sep 21, 2015
woodbridge,
Virginia
I know my vehicle isnt a sports car or whatever you guys have on these forums.. But i found a link to this website while doing google searchs on my problem.. The people on jeepforum.com havent a clue so i was hoping you guys could help me.
I have a 1998 Jeep grand cherokee 5.9 liter v8.. It came with a 150A alternator from factory.. The 5.9 Jeep was a very limited number production and because of this they dont have an aftermarket for its one of a kind parts which include this alternator.. I have to downgrade to a 136 for a direct swap... Which sucks.. and all the other 5.9 owners have the same issue.
So there are a few how to threads on how to get around this.. They call for taking the durango/dakota/ alternator from a 5.9 engine which are 160Amps and swapping it to our vehicles.. The only problem is these trucks are from 2001-2005 and in 99+ they changed the pigtail plugs on the alternators to a new standard. But the writeups show how to swap your old pigtail to the new one.. and its pretty simple..
I got 3 pigtails from a JY.. I cut off my old one and proceeded to follow the guide.. The guide called for cutting the ring connector off on the pos and negative cables as well because you need a larger ring connector for the positive bolt on the back of the alternator.. I did that and crimped the connector to the POS wire and also soldered it and taped it.. The negative i did the same thing.. Now the difference between the old alternator and the new one is the old one had a direct ground going to it.. The new alternator doesnt but all the guides say you can just plug the ground to a bolt behind the alternator where there are already a few grounds.. Which i did..
The other 2 wires go to the PCM which is where the voltage regular is "external regular" and something else. The guides claim the order these wires plug up doesnt matter.. The new pigtail had a solid green and a brown/orange wire. Mine were solid green and green.purple.. So i wired both solid greens together and the green.purple to the brown/orange..
I hook it all up and when i turned the key to the on position i had no gauges no power and no gas.. It wouldnt start either just crank.. I checked the fuses and i blew a 20A fuse in the box inside the engine bay which controls the Alternator/PCM/O2 sensor and fuel pump.
I tried a new fuse and same thing blew as soon as the key went to power.. I unplugged the pigtail on the alternator and tried a new fuse and it works and my gauges work, shows battery and fuel level... So the alternator is blowing that 20A fuse when the key is flipped in the on position.. Why is that ?? Did i wire these wires incorrectly ?? I dont see how the alternator could be bad.. Its brand new remanufactured. I dunno, i need my car its been sitting for over a week and ive been carpooling and sharing a car with friends.. I do landscaping so this is my lively hood.. I need this working. The only other thing i can think of is the old alternator ground pluged directly to the alternator.. This one doesnt have that.. But isnt the alternator case itself and the engine it bolts to a ground ? So i dont see why that would matter.. Maybe i should take the ground and bolt it to one of the case mounting bolts ? I dunno
Please help sorry for a long post but i wanted to give as much info as i could.
Here are pics on how its wired. And the link to the writeup.. as you can see its wired correctly i believe ? Maybe i should swap the green wires on the pigtail ? The solid green to the brown/orange and so forth ? I dunno...http://www.jeepforum.com/forum/f13/write-up-durango-160amp-alternator-swap-1330999/
can you post a picture of the back of the 160amp alternator? Id like to see if there is any spot that looks like a grounding point.
