2G 1995 eagle talon turbo awd
Glowskii
Apr 23, 2015
Anaheim, California
Well my question is I have done reading and I want to buy my dad some sparkplug wires and the little thing that goes inside the hole
Which are the best ones for performance , he is currently running stock except for intercooler (15 psi) and intake and stage 2 clutch
NGK BPR6ES spark plugs. They're the copper tipped ones and they come stock on our cars. A lot of other spark plugs like platinum or iridium usually cause misfires under load. As for wires grab a set of NGKs as well
Yes as long as your coils and spark plugs are not fouled. I've tried ACDelco wired before with the NGK spark plugs and they worked fine although its better to be just have peace of mind knowing its done right so if problems arise later, you know it's not due to some other company's wires. It's up to you but definitely get the NGK spark plugs at the very least! They're cheap af
Lol super conductors are the same as MSD, my bad I meant to say magnecore wires. Overall though, the blue NGK wires work best for most ppl
They should carry them but they may order them for you and receive them the next day. Give them a call or check online to find out for sure. If you're feeling impatient, check advanced auto parts or other places too
I just ordered them online and what's a bolt turbo I can buy something a little bigger than stock
The t28 turbo will bolt right on with your existing IC piping and is comparable in power to the big 16g but slightly less powerful than the E16g. Also there's the 14b turbo(smaller than 16g/t28) but both that and the 16g need a j pipe and custom IC piping. What power level are you looking for?
Look at the part number on the compressor housing and cross reference it with the part numbers of the t25, 14b, etc. and see what you got.
