Resolved 1995 cam angle sensor
gsx tuningart
80
3
Jan 18, 2005
Viterbo, Europe
hello to all. they are new of the forum. I write from Italy. I would have a question from makes you. I have a 95 gsx.I have installed the big 16G, rc550cc injector, fmic, apexi safc. naturally he is without Cam angle sensor. I wanted to put the cam to us angle sensor of one 1G. is one useful what or not?
which are the real advantages installation of the cam angle sensor?
thanks from simone.
up :rolleyes:
1 don't bump your thread
2 you do have a cam angle sensor... it is under the cam gear
3 you don't need a 1g cas to adjust timing, you'd be better off getting dsmlink since you are probably gopnna need it anyway if you did get a 1g cas.
IF you put on 550cc injectors and correct the airflow using an SAFC you will get all the timing you need.
4 Eat some gnoccis for me.
