1994 Eclipse 2.0 n/t
jefffbr
Dec 27, 2011
Beaverton, Oregon
Hi All,
This is the second time i have driven my car. Runs fine. After stopping and turning the car off. It will not start again. I'm getting a camshaft positon sensor code 23. I had a mechanic rebuild the heads and replace the ECU. He claimed that was the problem. Not the CPS. 6 months. Same problem. code 23. tried old ECU, and current. Same code error.
Anyone know the fix?
Help please
Thanks
Before swapping a new sensor in i would test the sensor plug for power and ground, and check for continuity in the 2 wires that go to the ecu. If everything there is good than i'd replace the cas.
I checked the plug coming from ECU to sensor. All numbers look good.
First time around, i reworked the heads. replaced the ECU. Took a bit of tuning after the work. According to the mechanic.?! He claims not to have needed to replace the camshaft sensor.
Car has run fantastic for 6 months.
Turned it off. same symptoms. Code 23.
