Badge023
- 76
- 73
- Nov 9, 2025
Ewing,
New Jersey
So I thought to myself back in November, this should be an easy restoration. Hell, I rotisseried a ‘72 Cutlass Convertible and fuel injected an Olds engine in ‘07 ish when there were absolutely zero parts available aftermarket. How wrong was I?
Anyway, I’ve found out that the engine in my ‘93 Laser is some bastardized installation that someone did… very well, I will add. I realized this when trying to change the motor mounts. There is no front motor (roll) mount. There are no provisions in the block to bolt one. So what I think I have is a 7 bolt, 2g block paired with a 1g transmission. My first question is simply, am I correct?
I bought a 91 GST as a parts car that is very complete and has the correct block drilled for the front mount. So is, (my second question ) or can this engine be either a 6 bolt or 7 bolt? I know the obvious answer is to pull the trans… but there’s 12 inches of snow on the ground, so “eff” that until the end of April.
Looking thoughts and muses as I chase another shot of rock and rye with a shot of Wild Turkey. Thanks in advance!
. All - Thanks for the info and quick responses! It’s much appreciated.
