twicks69
Supporting Vendor
- 4,340
- 2,092
- Mar 12, 2004
Milwaukee,
Wisconsin
The way it is, is correct.
Hey thanks. Does this apply to the 5th slider as well. More tapered side towards clutch housing?The way it is, is correct.
Correct that’s what I was saying. Last order I submitted some parts took over a week for them to say were unavailable and remove from order before I could pay.Also Amayama checks and verifies part availability before you are able to submit payment,
Thank you very much I sent a message to your Gmail!The TMZ874 is an invoice number, I have all the details if you want to email me and I can send over a copy of the original invoice.
Thanks for info. I work for Chrysler and have access to parts catalogs and dealer inventory. I found this at MOPAR vintage parts.Thicker side goes towards reverse, how did you find a new 5/R hub and slider???? They are all obsolete.
As well, all you really needed to do was flip your slider on the used 5/R hub and slider assembly and smooth out the witness marks in the hub splines with a die grinder and a 2" or 3" medium grit scotchbrite roloc abrasive wheel and it would have been easily reusable with the better splines facing 5th gear side.
Did you check and see if any others were available?
Maybe check on these if you could?
MD724118
MD747647
MD746443
MD749416
MD747638
MD746292
MD746824
MD747162
MD744349
MD741396
MD735299
MD744350
MD747651
MD746716
MD742536
MD743313
MD743316
MD748095
MD747885
MD744839
Wondering if I need to have this turned or if I can get away with reusing it with a new clutch and pressure plate??Looks Hot Spotted to me but not horrible. I've seen much worse.
I’m not confident in finding a reputable shop in my area that can do this correctly.Just me but I always turn them and verify the step height.
