General 1990 Talon TSi AWD Misfire over 4000 RPM
flyingfin
Jul 20, 2004
New richmond,
Got Talon 1990 AWD. Stroker Engine, EVO III turbo, 650 injector, 255 Walbro pump, 2.5 Exhaust, Stock 1G MAS, ECU+ engine management, Water ALcool. BIg front Intercooler on 2.5 pipe.
When I got over 4000 rpm at WOT the car is misfire i don't think is the fuel cut. I put new spark plug change nothing. If i put throttel at ½ or ¾ sometime the car don't misfire and climb to 7000rpm with anyproblem but each time at WOT the car misfire at 4000 rpm. The logger give me MAS frequency jumping a lot when is comming in the area of 2000 HZ it jump to 1200HZ to 2300HZ it is my problem? i got stock BOV at WOT my boost come over 20 psi but never the MAS read over 2300HZ. Sometime when i use the water alcool system when the boost drop and the water alcool shut the car stall the ECU of the car shut and i have to wait 30 seconds after that the MPI relay make is clic and i can stard the car again. I check and everything is good (ground and 12Volt power) anyone can help?
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
