low rpm misfire
dsmturbo444
Jun 9, 2003
I have a 91 Talon TSI, big16g 550ccs, MAFT blow through with 3" maf, 190 rewired fuel pump. MAf is set for idle and injectors, I tune with a SAFC. Im running 15 psi, and when just cruising around at like 2000-2500, sometimes I get a misfire, I though it was weather related, because it first only happend when moist out or raining. and I had read people having problems with the MAF translator, in wet weather. But It does it sometimes when its completely dry out. Anybody have any ideas?
Thanks, Clayton
Did you check your plug wires?
They are often the cause of sputters or misfires.
its possibly your plug wires, i had the same problem, i actually am have that same problem it seems to be misfiring at idle, im about to go down and get me a nice new set of stock plug wires
