1990 set-up with what sensors?
4g63telantra
454
Dec 10, 2004
Toronto,
K I have a 1990 6bolt Turbo motor going into my elantra with a 1990 EPROM ECU w/DSMLINK.
what I need to know is do I have to use any type of diff sensors then a 91-94?
Can I use a 91-94 cam sensor or does it have to be a '90?
Any other type of sensors I may run into that are not the same years?
it really depends on the harness you are using. if you have a 90 eprom go w/ a 90 harness. you will need : 90' coilpac and power transistor for sure. not sure about your guage cluster etc. im pretty sure you can use any year cam position sensor, you might have to do a little wire splicing tho. hope this helps you a little
