jdarnold1990
- 0
- Feb 7, 2013
Sullivan,
Missouri
Car idles fine a little surge but im running a little rich. when i put it in first it goes into gear fine but when i let off the clutch it will bog down to 500rpms and ill have full throttle and the car wont move or will barely move. is there anything electricle that can cause this if so what? and if not what could cause it. I HAVE ALREADY PERFORMED A BLT AND CHECKED BASE TIMING AND WITH A TIMING LIGHT FIFTY TIMES AT LEAST AND NO BOOST LEAKS
edit: did a compression test it was within 150-155 on all 4
