car runs like crap
turbotalon31
386
3
Jan 9, 2010
reading, Pennsylvania
ok i have an issue i cant get my car to run since i put in 680cc injectors mods are sleeper 20g turbo gm mass and translator , problem is runs so rich at idle and i cant tune it out translator is set at 6 base and 2 idle rest r zeroed out safc is zeroed out also just sputters and smokes like crap . one note i dont have a fiav it blocked off i dont have a chip yet is that what i need ?:banghead::banghead:
There's your problem.
When I first got my MAFT I had a 3.5" MAF and couldn't for the LIFE of me get it to function properly. After much research (and headaches), I found that the 3.5" MAFs are damn near impossible to tune (might not even be compatible). Switched to the 3" and all my problems disappeared.
Searching for a thread that explains everything in greater detail.
why would I have no problems then?? So that must not be the problem
The 3.5" MAF's *will* work, but I think part of the problem with them is that they exaggerate the issues with running the GM MAF. When you shove a 2" intercooler pipe in front of a 3.5" MAF, do you really think the airflow is evenly distributed across the whole MAF? I doubt it. Tom at DSMLink says the output Hz can vary 30-40% depending upon what size pipes and adapters you use. How the MAF is mounted, and any bends near the MAF further add complications to using it that way in blowthru.
Why yours works is beyond me. I just know that when I was setting up my MAFT/AFC combo I could NOT get anything better than a hard rev before it fell on its face and died.
Switched to a 3" MAF and my problems disappeared entirely. :hmm:
no i dont have the paper that came with it i have the base at 6 and idle at 2 if anybody has a better setting let me know also my safc is zeroed out
if there is anybody local will to take a look at it it would be very helpful im pretty new to this and got stuck when it cam to tuning
i think found out why i have the translator set wrong i quess there is a new and older verison i have the newer 1 and had it set for the older 1 ill find out tomarrow and ill update them
UPDATE problem solved got a chip from dsmchips and it solved all my issues car runs great. got my old chip of of an ebay vendor must have junk thanks for all the help
