1990 ECU in a 1991
Skillz
66
Dec 26, 2002
Biloxi, Mississippi
Hey, I've read the VFAQ about this topic, but it only tells how to put a 1991 in a 1990, and that it's possible to do this; however it doesn't say if a 1990 ECU will work in a 1991 car.
This is my problem. My car suddenly died while giving her a test drive after installing a stainless steel oil feed line on my turbo. Well, to make a long story short I took the oil filter bracket off, and sent it to a machine shop so they could take that inverted bolt out, when I got it back, I put it back on my car, hand tighten the oil filter, filled her with oil and went driving. Well, little did I know, they removed the oil cooler from the oil bracket when I gave it to them, and never tightened that bolt back up. Now, it all appeared to be on tight, when I hand tightened it, but that bolt came undone while driving around. Needless to say, all my oil came out of my engine, and all over the side of my car. I was going about 35ish when my car suddenly just died on me. All attempts to start it again failed. (I was stuck on a long bridge, at night, so I couldn't tell what the problem was.) Well, I got someone to push me off the bridge, and that's when I seen the oil was gone from my engine.
So I got my cousin to tow me back home, where I tightened that bolt. However, since then my car will NOT start. I figured it was the ECU, after doing some diagonistics. The engine turns over good when I try to start it. (Not too "freely" either) so I am sure I still have good pressure in the cylinders. I took apart my ECU, and I noticed the caps had leaked all over the board. I got a 1990 ECU from my cousin, that was workin just before we took it out of his car, but my car still will not start.
Any clues?
