jdxnc
DSM Wiseman
- 1,502
- 3,054
- Sep 15, 2009
Stanstead,
QC, Canada
12-1 allows the ecu to know where the engine is at any point during a rotation, allowing it to run simply off the crank sensor and used the cam sensor as a reference. You would still have a single tooth cam sensor. This way if the cam sensor were ever to fail, it would continue to run no issue.12 vs 12-1 on the standalones. What about the -1 is better if the home signal is still provided by a modified CAS?
I also use the same 2gb cam sensor for both crank and cam sensor, so lets say at an event I have my crank sensor fail, I can swap the cam sensor into the crank and still be able to run the car using Fueltech's diagnostic mode. Not sure if the other ecus can do this but I'd assume they'd have a similar option. This is not a fix for failed hardware but can keep you running in a pinch.
