16G turbo
If you simply hook a vacuum line from the lower intercooler pipe/j-pipe or compressor housing directly to the wastegate actuator, you'll run wastegate pressure boost levels, which usually ends up being around 11psi. A boost controller is necessary to raise above that level.
