16g turbo
eclispestar
402
Nov 29, 2007
everywhere, Washington
How guys I want to rebuild my 14b turbo I want to know can I use some parts off a small 16g and still use the 14b cold side and hot side?
The 14B uses a 6cm2 turbine housing and the Small 16G uses a 7cm2 turbine housing- however, the housings are interchangeable aside from their internal volume.
The only part you could use from a Small 16G on a 14B (or vice versa) is the turbine housing. If you try to install a Small 16G compressor wheel on a 14B center housing, the backplate will hit. You will need to have the center housing machined.
