16g question
spoolintsi97
56
Apr 16, 2005
Blandon, Pennsylvania
i want to get new waterlines with the turbo its the 16g evo III should i get first gens or second gens
also pictures of this install could help i have the sbr install kit anything i need to know about the way this kit installs does the banjo bolt that came with the kit connect to the oil feed line on the turbo because the give u a 90 degree fitting too
thanks for the help
If you want new ones get the 2nd gen lines since it appears that you are still on the stock 7 bolt motor.
It wouldnt hurt anything to reuse the stock ones unless they are in bad condition but if you really want to get new lines then go right ahead.
You can use the stock ones thats what I did with my old 16g. As far as installation instructions go, I would use vfaq.com. It has a step by step manual on the install with pictures.
Yeah i didnt know if the first gens worked better i wanted to get new ones so that if i brake them i will have others to back them up so i dont lose my car for a few days
thanks for the imput
