16g install
undrboost
44
3
Sep 6, 2005
Cincinnati, Ohio
newbie... help just installed a 16g on my 2g gst and trying to figure out where the vac lines hook up b/w the turbo and the boost restrictor the only place i see to hook them up is off the wastegate and lower intercooler pipe but not sure?
Engine Primer would be a good place to start. Also VFAQ has a write up for doing a 16g install in a 2g. The rules here are very clear that you should research before you post, please do so so that you don't get banned. There are alot of people out here that can help you when you REALLY need it. Good luck with your install!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
