16g install
eclipse4life082
Jan 22, 2006
pulaski, Virginia
i just bought a ebay 16g and install kit i know ppl say there not that good but i figured i would try one out it came with everything j pipe, oil lines ,and all gaskets and nuts i just need to know how much boost i can run on stock fuel system and what yall recomend i up grade to for this turbo and what kind of data logger to get for my 2g turbo dsm thanks
As far as running on a stock fuel system, I believe it's around 14-15psi, I would just go straight to the fuel supporting mods, and if you wanna go big go with 255 walboro (rewired of course), Afpr , 750cc's and dsmlink, I just went a little smaller with a safc, 190 and 680cc (which is the max size the safc can hold) good luck.
Get supporting fuel mods before you up the boost on the 16g. From what ive read on the ebay 16gs they seem to perform pretty well. If your on a budget since you have a 2g you can get away with some EVO VIII injectors and EVO VIII pump (rewired) which are direct bolt ins. Then get a logger, wideband and some sort of fuel control. Start boost out low until you learn how to tune your car for no knock. Good Luck with your build
