16g dying wastegate
idt512
231
9
May 4, 2003
Hemet, California
I bought an Evo3 16G a few months ago that was lazy on building boost. I shimmed the wastegate with 3 washers for a total of about .190" inch, and everything has been good since, well 4 months later and I notice the turbo losing peak boost, and then a few days later it was lazy to build boost all over again. So i inspected the wastegate and found that i could move it 1/8" by hand again. Added 2 more shims to about .250 and all is well again... But im curious if wastegates fail this way? Or is something causing my wastegate to lose tension?
Upgrade to a holset actuator bro! Be done with loosing boost haha. The wg just can't handle the psi your trying to push and blows open easy. Also have you done a boost leak test or inspected turbo for shaft play?
At this point the flapper's barely opening at all with 1/4" of shim between the actuator and the mounting towers. Full arm travel is only about 3/8" on a new 16G actuator.
Something's either wrong with the actuator or the turbo, or you have a massive boost leak somewhere. Try replacing the actuator altogether with a new one or a known-working unit to see if it fixes your problem.
I've checked for boost leak and verified it as well by watching my AFRs and look look right on target still. No pre-turbo exh leak. Car runs & drives perfectly fine in normal driving. My other thought was a clogged aftermarket catalytic. But the fact that the wastegate arm had play all over again tells me it's the wastegate.
