16g checklist
lucid15
527
Oct 10, 2008
Portland, Oregon
So i tried to go a cheaper route by buying individual parts and some used and what not and wanted to check to make sure i have everything needed for my evo 3 16g install coming from a T-25.
  • O2 housing gasket
  • OFH feed kit from Extreme PSI
  • Oil return gasket
  • J pipe, with silicone hoses and clamps
  • 7cm cometic gasket
  • J pipe gasket
  • 560 CC Injectors
  • Evo 8 Fuel Pump
  • STM rewire kit
So i think thats all i got as of now. I plan on portin the turbo as well, do i need to port anything else? and what else do i need to order to complete this?
I recommend you feed oil from the head, unless you are running a restrictor from the OFH.
AFPR, i just got the same system, id go with 650cc's instead. im sure you got fmic already. gonna need a wideband.
Going with the stock sidemount and have also heard that the OFH is fine, its kind of a tomato tomata type thing when choosing. And i dont think i need an AFPR with the Evo 8 pump as it is the same size as the 190
The OFH is fine for an EVO316g as far as feed. They aren't AS sensative to pressure as other turbo's out there. Plus the oil at the filter housing is cleaner than the stuff coming from the head.
I would recommend an Evo 9 pump over the Evo 8. What will you be using for exhaust piping (size)? If you haven't upgraded as of yet, you may actually consider sticking with something smaller like 2.5 inch piping instead of opting for full (or partial) 3 inch piping like most others do. This will definitely help with keeping boost creep at bay.
I have a full 3" TBE. i think it bottlenecks at the downpipe to 2.5". its the SSAC one.
  • Wanted 6 bolt NT water pipe
    • chrisman287
