16g Swap Checklist!
Afizzle
348
Jan 16, 2013
Dallas, Texas
Things I do physically own vvvvvvvv
-Small 16g w/ ceramic coated hotside
-FIC 750cc low impedance
-Walbro 255
-Aeromotive FPR w/ gauge
-Full 3" exhaust
-3" DP w/ cat deletion
-Dejon intake w/ KN filter
-NGK Plugs/Wires
-Boost leaks all fixed
-Punish FMIC w/ J Pipe
-Boost Gauge
-Water Temp Gauge
-Oil Pressure Gauge
-AEM wideband
-3 pod pillar
-2 pod steering bezel
-Greddy Type S
-16g Install kit
-DSMLink v3
-FP Exhaust Mani w/ ceramic coating
Things I know I need:
Competition clutch stage 2 or ACT 2100
16g/14b wastegate actuator for internal wastegate
I feel like im missing something. when I order the actuator new from EPSI.com, will I need any hardware to put it on the turbo?
exactly what hardware should I buy and from where to make sure that the install goes smoothly. i hear exhaust mani, o2 housing, and exhaust mani > turbo bolts all tend to break.
Also any other gaskets i should replace such as VC gasket or TB gaskets to keep the new higher boost in check? i plan to run 18-20 psi
:dsm:
That's more then enough for 20psi.stock manifold and o2 will be enough but if you got the extra money spend it. Lost looks good. 2g head gaskets are good. Exhaust gaskets and bolts are good idea to change out. You dont need to if they dont break when you pull em out. If throttlebody leaking then you can fix that, do boost leak test. If you're vc gasket leaking replace that. If not your good.
That list is definitely overkill for such a small turbo at low boost but these extra things definitely put you on the right track for a big turbo. I would recommend getting oil drain gaskets as those little guys like to rip and stick to the oil drain line flanges. If you've already done a blt and you don't have any leaks you should be fine with the few pounds of added boost.
  • Wanted 6 bolt NT water pipe
    • chrisman287
