16G came with no wastegate actuator!
HooahGST
77
Dec 9, 2004
Fort Bliss, Texas
Ok...bought this 16G and i guess its my fault for not really asking if it came with the wg actuator...
so my question is:
Will the WGA from my T25 work on the small 16G?
The guy also welded shut the wg hole. So I either fix all that and try and get a wga that works..OR?
I buy a new manifold and get an external? Been browsing around here about that but dont want one that has the WG on one exhaust runner...Been told thats no good. Trying to find one that has the flange at the collector. Any ideas? Prices? HELP!
And dont worry, I have all the supporting mods in a box just ready to be put on(logger, SAFC II, 550's, 190 pump)
HooahGST
No the T-25 actuator will not work on your 16g. Only a 14b or 16g wastegate actuator will work. I'd say it would be cheaper to find somebody to fix the flapper. I'm sure an exhaust shop could help you with that. Hope that helps
You got a turbo that's been converted for use with an external wastegate. Buy another turbine housing (they're super easy to swap out) and another wastegate actuator. It'll be cheaper than putting an external wastegate onto your current setup. I had to do the same thing with my 18G. You can find both of these items on eBay occasionally.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
