JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Where is this science, and if there was that much testing done why is the only factory 4G63 turbocharger that is fed from the filter housing built by Garrett while all MHI turbos are head-fed from the factory?Mitsu designed the housing that way for a reason...for all OE turbos that came on the 4G63 the OFH is the best place. There was a lot of science done to make that the preferred spot for oil on the MHI turbos when run with OE parts.
I'm defending the head as the proper oil source for pressure and restriction for a MHI center housing.If the OFH is the best place for MHI turbo's then why do all 1g's feed from the head? And Evo's?
It seems that no one can track down the oil pressure requirements for a MHI turbo, but apparently it's much less than a Garrett. Mitsu fed these turbos from the head with a restrictor in the line from the factory for a reason....if you venture away from this source, you're risking pushing oil past the turbine seal as well as adding unwanted stress on the journal bearings and turbine shaft due to excessive incoming oil pressure.
Matt has stated above that his brand new Small 16G and FP 18G both smoked when fed from the filter housing on his 1G....if that's not enough reason for anyone to stay with the head as the proper oil source for a MHI turbo, then I don't know how much additional proof you need.
