1500k rev and dies
95burgundyesi
816
9
Feb 8, 2006
Rockford, Illinois
Well I finihsed my 6 bolt swap and the idle it perfect and sounds very healthy with 15 pounds of vac. But when I rev it to about 1500k it cuts down back to idle and if I do not give it gas it will die. But I can save it and then it idles fine. Up to 1500 is hold fine and it will rev past 1500k but I need to apply more gas.
I am going through every hose I can think of and I am aboutt o do a boost leak test. Any ideas?
Yup just did it when I got off work, would hold 10psi then I found the leak at the pcv valve on the back of the valve cover. Fixed it and brought it to 18 psi and the tester came off LOL make a big pop. So I am fixing it right now and aiming for 22psi. Then I will start it back up and cross my fingers.
