Dies after rev
lucid15
527
Oct 10, 2008
Portland, Oregon
So i just took my car out for a spin. I installed an intake system a week ago and my BOV IS recirculated. I got on it from 1st to 2nd and after boosting through second i let off the gas and put in the clutch, it died. Then i tried it again and died. Sometimes it doesnt do it, it will go to about 200-300 RPM but not die. Other times it will not die but the lights will come on for a sec like as if it were dying. Do i need to jut adjust my idle screw? Any thoughts?
It might be your ISC a/k/a Idle Speed Control.
If it is you can get one from www.DSMISC.com
I got one from them here in a box but have not yet installed it.
I will check them again tonight, i have to clean out the IC anyway so ill double check all lines. But its been going PERFCT for 2 weeks until now. All lines have been clamped as well.
if they are all original line they are likely old and cracked. if you end up having to replace them. just buy a bunch of it and replace one line at a time so you dont get lost trying to remember what connects where:thumb:
still cant figure it out. it idles flawlessly at rest, it just bounces if im coming from 3k or above RPMs before returning to idle... any more thoughts?
