14b with the usual problems, what are the pro's con's of these options?
manwithaGSX
80
Sep 6, 2005
DFW, Texas
Well I've been working on my car for a week now, pulled everything off the motor besides the tranny and rods/pistons. A new Dejon 3" is going on, balance shafts have been removed, repaired/reinforced two motor mounts, and bought a all metal radiator. I wire-brushed the exhaust manifold and 02 housing insides as well as a little grinding. Well when I started to clean the turbo I noticed the crack around the flapper which more than explains the slow spool and the max 9 and 10lbs of boost I've been getting. Also when I blow into the compressor side of the turbo and block off the outlet I can hear air leaking into what maybe where the oil runs through.
Reading various posts I have learned that getting it welded is very temporary, and the leak warrants a rebuild at the very least. The problem is I've more than cashed out buying everything I'm already doing to the car and I need it to be drivable soon.
1. So, until I can afford to rebuild or replace that turbo, should I just hook the filter and maf straight to the throttle body to avoid the overly rich boost spark plug fouling leaking turbo and disconnect the flapper? or maybe in addition to that remove the exhaust turbine?
2. If anybody knows of a cheap way to replace the turbo with some sort of piping so I can sell/part it out on Ebay that would be great too.
3. Any other suggestions would be GREAT!!
With no oil pressure on your CHRA, air will leak through. I am not too sure what the amount of air that you were blowing out with human power represents, but I have read that during boost leak tests (20+ psi), it is normal to hear some air moving through there when the tester is connected to the compressor inlet.
As far as the cracked turbine housing, how bad of a crack are we talking here? As many miles and heat cycles that it has prorably seen, cracks are not surprising. You could always check the trader for a 6cm or 7cm housing to replace yours.
Hope that helps.
Thanks for your reply
I did not know that about the CHRA, and yes I just put my mouth against it and blew. I figured the crack was the main reason for my slow spool and low boost pressure even with a MBC, but exhaust manifold nuts had come loose too. Other than those what could cause that? Here are pics of the crack.
