14b turbine wheel replacement?
I_DECLIPSEGT
Mar 11, 2010
Tulare, California
Well this is my first post on the site. Been on the forums for a while now. Mostly using the search button. :thumb:
Well im working on rebuilding a 14b turbo and while taking it apart I noticed this
Does this turbine wheel need to be replaced? Where is a good place i can buy rebuild parts from?
Yes check out the freelancer on turbo rebuilds there are a few out there, the seal looks bad, im rebuilding my evo 16 doesn't seem that bad there found me a nice kit.
You need a new turbine and a full rebuild. If the rest of the turbo is in nice shape and worth rebuilding, you'll have a practically-new 14B when it's all said and done....otherwise you may want to spend the money on another turbo if there are any large cracks in the turbine housing or other reasons it's not worth repairing.
These are the only cracks in the turbine housing.
Yea I picked the turbo up for 50.00 hoping that all it needed was a rebuild and balance. Looks like itll be getting a new turbine wheel and shaft.
