2G 14b oil drain options
awesome
154
8
Nov 30, 2013
Union, New Jersey
I currently found a leak in my oil drain on the housing to oil pan. And I'm using adapters with a rubber hose to connect everything. I'm looking at options that will fix this and so far I only see oem, I think it's redicolus to pay $70 for a oil drain. So I'm wondering what someone else might suggest. An fittings or something that will last.
Thats roughly what you'd be paying for a oil drain kit with -an fittings and lines. Unless you find a local store with pushlock fittings and use a cheap rubber line.
Oil drain is something you don't wanna be cheap with, IMO.
Also the bolts to the oil pan also have special washers with orings in them to prevent leaks make sure u have those and the correct bolts extreme psi has them for cheap.
