14B Install Help Please!
4G63dsmpwr
307
Sep 13, 2002
Easton, Massachusetts
Well I just purchased a new manifold, and a new 14B. I was wondering if anyone knew the following part numbers:
Manifold --> Head (bolts, nuts, & washers)
Manifold --> Turbo (bolts, washers)
Turbo --> 02 (bolts, washers)
The reason I am asking is I know this stuff gets pretty hot, and want to use the right hardware. Is there anyway to get the right stuff without going through the dealer (I think this might get expensive)?
Also, I'm going to purchase all new gaskets: Are there any gaskets which are better than the OEM ones? The turbo only has 30k, and is in great shape. I will be running between 18-20lbs on it, and don't want any trouble down the road.
Thanks for any help!
If you want to run that much boost you bouht the wrong turbo. Should have bought a 16G small or bigger. OEM gaskets are best.
I happen to have CAPS so I can hook you up with the part numbers.
Head Studs are MD146938 qty:2, MD005317 qty:7
Head Washers are MD050076 qty:2 MD041192 qty:7
Head Nuts are MD092806 qty:7 MD165789 qty:7
Turbo Bolts are MD132656 qty:4 Washers MD132933 qty:2
O2 Bolts are MD062961 qty:3 Stud qty: 1 MD050074 Washer:MD132933 qty:1 Nut:MD132930 qty:1
That should cover it.
Thanks for the help!
Quick questions:
Why do you have 7 & 2 for the manifold bolts/nuts/washers?
Why 7 & 7 for the manifold bolts (14)?
Why only two washers for the turbo bolts?
If someone could explain that it'd be great! Thanks again for the help.
