14b approaching 20 + psi, good afr's :-)
jeff24680
223
6
Jun 2, 2008
Allen Park, Michigan
Hey all,
Just would like to say thanks for all the great info here.
This post is here to share my experience on what I have done and what my methodology consists of, it is open for criticism and comments.
Just want to say that my mod list is current and right now I am currently boosting 20psi with AFR at WOT no higher then 11.5 to redline, I am on the stock fuel pump and injectors. The fuel pump is re-wired according to this write up http://www.dsmtuners.com/forums/articles-electrical-wiring/313914-2g-fuel-pump-rewire-pictorial-diagram.html after some logging of 3rd I am receiving around 1-2 counts of knock around 5000rpm, I also notice my temperatures are hovering around 210.
So to remedy this situation I have purchased the following and plan to do the work this weekend
  • BPRES7
  • 2 Bottles Watter Wetter (currently running full 50/50 mix :/)
  • 2 12" Mishimoto Slim fans(Going to wire so when Rad fan comes on so does AC fan)
  • Sparco Rad hoses
  • DEI Exhaust Wrap(threw out my heat shields after replacing tranny and all other parts, DOH! :banghead: )
  • DEI Silicone High Temp Spray
  • 170* Thermostat
  • All new silicone vacuum hose 20 ft of 3 different sizes(can never have enough hose)
  • I am running Castrol Syntec 0w 30 Imported from germany
  • Using the seafoam treatment
  • 3 4ga Grounding wires to replace old wires and add 1 or 2 extra going to follow http://www.dsmtuners.com/forums/articles-electrical-wiring/75889-homemade-4-gauge-grounding-wire-kit.html
With this I hope to accomplish:
  • Temps never higher than 200 unless pushed really hard
  • Knock elimination
  • Reliability
  • Idle
  • Throttle Response
  • Better electrical regulation
Opinions and ideas are welcomed, If you didn't read my profile I am using 94 Octane daily as it is available readily in my area.
I have logged my IDC and yes it is close to 100% I am aware but this turbo and injectors only have to last till March.
Tuning and Logging is done using EcuFlash (Using Extended maps, modified to my liking) and EvoScan 2.6, I currently have a BL at my HKS flange on my IC piping so I have also ordered a new ring seal and hope to remedy that along with some RTV for good measure.
This is my 2 cents....
FORGET the water wetter. I ran hotter using it than just a regular 50/50 mix.
GO with the lower thermostat. I notice big differences when I replaced mine.
GO with a rewiring of the fans, you don't need new ones. I ran a jumper wire in the fuse box so now both fans come on.
The rest of your stuff you listed is more personal preference, not a big deal either way I don't think.
How did you use the water wetter? I.E. what was your mix. I have read many threads praising it for helping out even if only slightly. I am planning on 30% Anti Freeze and the rest water and Water Wetter
170* Thermo I believe is 10* lower than stock not 100% sure.
As for Exhaust wrap and spray I don't believe that is personal preference but then again it is to some extent that I am choosing it. It has been proven though that by removing your heat shields temperatures will rise. I don't need added heat, and the exhaust wrap gives it an added touch
But yes hoses and stuff are preference.
I wanted the new fans anyways to give some more room in the bay and a somewhat cleaner look.
Thanks DSM4me44 for the comments.
I see you are from Canada. Gets pretty cold up there in the winter. Is 30% antifreeze going to give you enough protection?
Yah right next to Detroit, From what I read unless your living in negative temperatures for 1-2 months plus 30% should be more than enough. We do go into the negatives but never below -10F or -15F. However I will do more research on that.
Did you use 50/50 or mix it yourself Give us a bit more info
I've heard alot of people that used just distilled water NOT tap with water wetter for cars that don't see the Cold and seen a big difference
I will not be able to get a log until after I install these parts, probably by monday night but I will definitely get a 3rd and 4th pull. I believe(don't quote me) Air flow was hitting 1650 Hz or 200 load at 4800-5500 RPM. I have not been able to go above 200 load for some reason, either it isn't logging right or --> I have not been able to locate the coding for it in the Rom. I believe Ceddy has located it but I have not been able to change it yet.
However I will post the last log I did where I noticed the knock count.
Edit** I just noticed you said AFR not air flow. I will post back with results Monday for everything
I added a bottle or 2 of water wetter mixed with water. I didn't mix it with antifreeze, which could result with a difference in performance of the wetter itself. I found the combination I used didn't work so well.
I am running 20psi as well on my 14 and do not have heat issues. The 170 thermostat is a great thing like i mentioned before, that made a huge difference for me. I am not running heat shields of any sort. Both fans are hooked up thou to run when the first kicks on.
I wouldn't go near 11.5:1 on pump even without or little knock. 10.8:1 is where I stick around. That creates a lot of heat and as we know heat = failure. Might run great now but just saying.
AirFlow_Hz max out at ~1600 Hz
ECULoad max out at 160
I have a edited EvoScan file I will be releasing with my next CeddyMods.
It has the 2Byte Load, AirFlow_Hz, RPM, and AirFlow_Calcs(log g/sec or lb/min)
This allows logging of any value. I also removed useless items and added a lot of new items to log.
If you wish to log 2Byte Load, you need to edit the MUT table in EcuFlash:
MUT00, change to F2A4. ( Hit = then enter 0xF2A4 )
MUT01, change to F2A5.
Be careful with you Injector Duty Cycle if you are near 100%.
Colder weather allows a lot more air to be ingested at the same boost level.
100% Duty on a Fall day, could easily be 130% Duty on a cold Winter day.
Ok Ceddy Here is the MUT table I know the first two values along the Y Axis are MUT00 and MUT01
However, they also have 15 values on the X axis so which one do I change to F2A4 and F2A5
I would think the stock fan would move more air than a slim fan. 0w30 oil sounds kind of thin if you're really beating on your car.
It is getting colder here so 0W 30 is perfect for the season :)
**Update**
Hey guys manged to get everything installed by Monday and what can I say, great stuff! My temps will not go above 200 at idle now, have not got a chance to do 3rd and 4th gear logs yet as Area is limited around my house for a location to do that, Will try and get one before weekend. My idle AFRs are still around 16 I cannot figure those out and Vacuum at 750 idle is 17 in/hg. Will report back.
