20 PSI!! 14b CREEP
PropXprt
431
Oct 19, 2002
Springfield, Illinois
First off I am running a 3" downpipe only; my boost creep is jus wild, I installed a mbc today to see if that would help, but it did not, so I am wondering would installing the rest of the exhaust help control some of this creep. ?? :barf: makes me sick, that gauge goes to 10 ish then flings its needle right up to 20! uhhh...
Dude I had the same problem.
Heres what you have to do:
1. Port O2 housing to hell
2. Port the WG side of the turbine housing and get a 34mm flapper from TRE
3. Maybe get a larger A/R. Say like a 7cm^2.
Rob
I got my stuff ported by RRE or Road Race Engineering. They do a pretty good job and send you a piece and credit your account when you send them your stock part back. There is no down time with them.
www.roadraceengineering.com
TRE is Team Rip Engineering. They don't port anymore, but I got one of the last ported 7cm^2 turbine housings they sold.
www.teamrip.com
FFWD Connection looks like they do some damn fine porting.
www.ffwdconnection.com
Slow Boy racing is a new found favorite of mine. Slow BOy looks like they have some good special that will port the hell out of the O2, turbine
housing and install a 34mm flapper, and port the manifold. All this for $230, which will most likely stop that boost creep in its tracks.
www.slowboyracing.com
Rob:thumb:
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
