120 trap 90 AWD street car
john8428
Jan 15, 2012
Rochester, New York
Name is John, originally from Rochester, NY. I am currently in the army serving in Afghanistan as I type this. I picked up a rust free 90 eclipse gsx about 3 months before I deployed. Car is being built by Dan Frisch in New York. I guess I'm new to the scene being that this is MY first turbo dsm but I've been around dsm/evo's for quite a while, hanging out with a few STM guys and Dan. I figured I'd post my build sheet and see what many had to say about it and get advice on my goal for the car. I'd like to trap 120 in the 1/4
Build sheet
Rpf1's 16x7✔
Evo3 16g or PTE 5858
Coilovers?? Megans
Clutch?? Act2600 or Southbend
Avid Billet Motor Mounts✔
Exedy master✔
Exedy slave✔
STM Ss clutch line✔
STM Shifter Cable Bearings✔
Punishment FMIC w/piping✔
Exhaust 3" ???
1g Bov ✔
1g FPR ✔
FP Race Manifold✔
Megan o2 Housing✔
Stud kit- mani✔
Stainless Steel Valve Cover Bolts✔
Oil Cooler Delete Bolts✔
STM Egr Plate✔
Front bumper✔
Timing covers✔
JMF Small battery kit✔
Intake?? 3" or 4"
Cams?? Kelford 272 or Comp
Topline Revised Lifters✔
Evo BeeHive Upgraded Springs✔
Evo Retainers✔
Inspection Cover✔
Gates Timing Belt✔
Timing kit
DsmLink v3lite✔
2 Gauge Vent Bezel✔
Aem Wideband✔
Aem Boost✔
FIC 1000cc Injectors✔
GM Maf✔
Maf Translator✔
Walbro 255✔
STM Fuel Pump Re-wire kit✔
FIC Injector Seal Kit✔
Fuel Lines & Fittings
Any advice is greatly appreciated
Ditch the MAFT and use the money to upgrade your ECMlink from lite to full. Unless the checkmarks mean you already have those items... Even then I would sell the translator and put the money to link full.
Yes check marks mean I have those parts. That setup came with the car already but that's something ill look into. Thanks for the advice
You shouldn't need V3 full to use a GM MAF without the MAF-T. I'm pretty sure the new versions of V3 Lite allow you to choose preloaded mas airflow maps for the the 1G, 2G, Evo, GM MAFs from the drop down menu.
Although I could be wrong. Its been a while since I've messed with V3 Lite.
I would go with the pte turbo and run an intake as close to the same size as the turbo needs as you can. The transition from say a 4" intake pipe to a 2.5" turbo inlet is so turbulent that it will hurt topend power and airflow. Smooth flow is critical, not just pipe size. so get the same size pipe as inlet or atleast very close. Also act is a great clutch IMO.
You will need the GM maf cable.
ECMLink (DSMLink v3) GM MAF Cable DSM
Little update on the build sheet
Build sheet
Rpf1's 16x7✔
Evo 8 shift knob✔
Fp old school red✔
D2 coilovers✔
Quartermaster V-drive twin✔
Exedy master✔
OEM slave✔
STM Ss clutch line✔
Vr 3" turbo back✔
1g Bov ✔
1g FPR ✔
FP Race Manifold✔
Megan o2 Housing✔
Stud kit- mani✔
STM Egr Plate✔
Custom intake 4"✔
Comp 272s✔
Evo Retainers✔
Gates Timing Belt✔
Timing kit
DsmLink v3lite✔
2 Gauge Vent Bezel✔
Aem Wideband✔
Aem Boost✔
FIC 1250cc Injectors✔
GM Maf✔
Maf Translator✔
Walbro 255✔
STM tank to rail kit✔
Powerslot rotors✔
Hawk pad✔
