-10AN oil return steel weld bung
I've never seen a weld-in bung like that. These are the options I know:
1. Get a bolt in bung
2. Get a weld-in bung and also weld the bolt holes shut
3. Get a n/t oil pan, drill your own hole, and use the weld-in bung
If possible I would weld it. I am lucky on my car, but it seems the bolt on ones leak on every other car i've seen them on and constantly rattle loose. A good weld won't leak or vibrate loose.
I plan on doing mine soon.. I picked up an NT pan for 15$, and the fitting is ~10$ at summit, so it will be well worth getting rid of the leak and even the possibility of a future leak.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
