oil return tube
Yeah, I don't get the idea of that piece of crap. Hit up an industrial supply shop, or a diesel truck or Caterpillar shop, and get a piece of silicone hose. I'll bet they even have elbows. Or if not silicone, at least some oilproof line. Tell the counter guy what it's for, he'll have a solution.
Thanks for the replies, today I cut out the flexible section of the tube, filed the edges down smooth and ground down the weld bead to create hose nipples on each piece, then got a piece of high temp hose and clamped it to the two pipe ends, works great, no leaks & still flexible. Only problem is I need to replace the high temp hose with a silicone high temp like you mentioned, because the piece I am using temporarily is just high temp water hose.
Thanks
