-10 psi at idle , vaccum leak?
318Batman
Sep 13, 2012
Bossier City, Louisiana
alright heres the deal.
my buddy just picked up a 1997 GST, only mods are thermal full 3" exhaust, real type s BOV, boost controller , and HKS 264 cams. I've read that vaccum is supposed to be between -16 - -20 at idle. this car is showing -10 at 6-800 RPM's.
any help would be great, we both are new to DSM's :thumb:
Just so you know, that spec is -20 in/hg. Not PSI.
And cams will make your vacuum decrease, mine is a solid -15 in/hg at 900 rpm. Try bumping the idle up more to see if that helps. Otherwise you can do a boost leak test to find any vacuum leaks.
-6 psi would actually be about -12.2 in/hg. It's pretty close to a 1 psi to 2 in/hg ratio.
Thats correct. I actually posted the measurements myself in a diff thread. Though I just switched from a,digital to manual gauge,and digital read -6 and manual reads about -17-18 in/hg hmm guess that tells me,one of these gauges,are off.
