02 sensor issue
dsm4444
74
Jan 21, 2007
Burlington, Kentucky
Would your engine light turn on if your o2 sensor was going bad? I think my sensor behind the cat is going out. My fuel milage is horrible and i keep getting a surging issue. The surge goes away for a day or two everytime i rewire my sensor. Now i know for sure the sensors soldered on there well and its still acting up. But no check engine light....?
The CEL will light when either o2 has an out of range signal, or a heater circuit malfunction. There is also a CEL if the reading from the downstream o2 is the same as the upstream's.
The downstream sensor has no effect on your engine.
Well i know thats not true because when i first rewired it i left one unwired on accident and it sent my engine through hell and back til i found out.
It is true, the only function of the rear O2 is to tell the ECU that you have a functioning CAT and will have absolutely no effect on engine operations.
Ok i believe you but would it have an thing to do with the fact that its a straight through cat? Maybe thats sending something wrong?
No, the reason the ECU wants to know if you have a functional CAT is for emissions purposes, you can run an open down pipe and your engine wouldn't care. The front O2 however will directly affect your close loop operations.
o i c.. So ill check out the sensor on the down pipe. How often do those sensors go out? i have a 95 talon.
k Well i took out the front o2 sensor and found that its chalk white... is this bad.. the one in the rear is blackened. I understand that the front one takes the most heat being right on the headers but still...
