02 sensor
madjoker6000
May 30, 2011
wallins, Kentucky
ok just wandering i have a o2 sensor from the stock and the wires are 2White,1Black,1Gray,. the question i have is i have 2 more 02 sensors with wire colors 2Black,1White,1Blue the plugs are the same of mine and plug in fine to to harness so i was wandering if i could use them in it if they would read the same on it thanx for any help
Can you see any part numbers on them? I have seen different brands use different colors before. The other way to tell is to plug them in and see if it works. I prefer to go with the cross reference before the trial and method though.
Also, it may help a little if you worked on your grammar and punctuation. It was a little confusing at first to read your post. The forums are a much more helpful place if people can read and understand your post. Just a friendly heads up before somebody gives you a hard time on it.
