Justin DuBois
DSM Wiseman
- 3,399
- 3,375
- Aug 15, 2019
Oakland,
California
Yes - those Banjo pipe fittings are for Air/Oil cooler oil lines. I went with an AN fitting here with 90deg hose ends. Maybe next time I'd consider a set of hoses with Banjo Hose ends.No kidding. The makeshift wooden one was ok, but this one works so much better.
Test fitting going well. Getting a follow up list to order. Cam degree kit, castleplug, inch lb torque wrench for timing belt, some misc hardware.
Forgot about OFH. Started to take that apart to clean it out and the, assuming, oil plugs (big Allen plugs) are fairly seized up. Need to figure out what else I gotta replace on this. I think it had a set up for an external oil cooler - haven't read up on these at all (OFH and oil coolers).
