Over heating solutions
Is there an answer for overheating
If you turn off the motor, it will stop overheating.
If you have an actual technical question about a situation you have encountered, and parts you have verified are working we can help you solve a problem. However; based on your question I have to assume that you have not checked the basics of the cooling system and have not checked the level of coolant in the radiator for your vehicle
Please verify with us that you have full coolant under the radiator cap. If the fluid is full I need you to verify the cooling fans are functional on the car when the motor is hot. If the fans on the radiator are working I need you to verify that you have replaced the coolant thermostat. If you have verified all three of those have been checked and the thermostat is replaced we will need to hear more specifics about your vehicle such as what modifications for performance you have done
  • Wanted 1g Need 1g AC tensioner bracket
    I am in need of 1g AC tensioner bracket - looking for complete with bolts. Recently bought 92...
    • JLavetsky
    • steelcurtaindsm
    • Syclone#334
