Spyder 1998 Spyder GS - Driver Rear Quarter Window Went Down, Now Completely Dead.
sirhecker
Jul 22, 2026
Victoria, BC, Canada
Hey everyone,
I’m new to the DSM community and currently restoring a 1998 Mitsubishi Eclipse Spyder GS. I’ve been slowly bringing the car back after it sat for quite a while and have already fixed several electrical issues.
My biggest issue right now is the driver-side rear quarter window.
Here’s exactly what’s happening:
  • Driver rear quarter window went down normally using the driver master window switch.
  • Now it will not go back up.
  • Pressing the switch UP is completely silent. No click, no motor noise, nothing.
  • The window is now fully buried inside the quarter panel, so I can’t grab the glass to pull it up manually.
  • Rear seats and interior trim are already removed.
  • I removed the rear speaker and found the access holes behind it, but I still can’t actually reach or see the regulator because it’s hidden behind the inner body structure.
  • I also found what appears to be the larger Spyder control module behind the rear seat (black box with blue and white stickers), but I haven’t replaced anything yet.
Other window behavior:
  • Driver front window works.
  • Passenger rear quarter window works.
  • Passenger front window currently does not work, but that’s a secondary issue and my priority right now is getting the driver rear quarter window closed before I continue troubleshooting.
My questions are:
  1. Has anyone had a rear quarter window that would go down but then become completely dead on the UP command?
  2. Is this more commonly a master switch issue, the Spyder control module, wiring, or the regulator/motor?
  3. Most importantly, is there a way to manually raise the rear quarter window while I diagnose the electrical problem? I’d like to get the glass closed to protect the interior.
Any advice, service manual references, or photos of the regulator/access points would be greatly appreciated. Thanks!
  • For sale 2g 1999 Silver Faced Gauge Cluster
    1999 Silver Faced Gauge Cluster $120 + shipping & paypal fees* the cluster is a turbo/manual...
  • For sale 2g 2G Third Brake Light
    2G Third Brake Light $75 + shipping & paypal fees* 4 oem mounting bolts includedYou must be...
  • For sale 4G63 Aeromotive FPR
    Aeromotive FPR $85 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 2g 2G Gauge Cluster Gauge Pod
    2G Gauge Cluster Gauge Pod $25 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 4G63 Spark Plug Cover ( Financial Mistake )
    4G63 Spark Plug Cover ( Financial Mistake ) $30 + shipping & paypal feesYou must be registered...
