2G Is it normal for these cars to show such low oil pressure at warm idle
zheter
Jan 22, 2025
Spring, Texas
I have a 1998 Eclipse GSX. Today I resealed the oil pan using Permatex Right Stuff RTV and did an oil change at the same time (Mobil 1 10W-30). Everything went back together fine, and there are no major oil leaks. The oil level is also right at the full mark.
My concern is the oil pressure. Once the engine is fully warmed up, the factory gauge drops to almost the bottom line at idle. While driving around town it comes up to about 1/4 of the gauge, and on the freeway it climbs to nearly halfway.
Is it normal for these cars to show such low oil pressure at warm idle, or should I be worried?
From what I've found while searching, a faulty oil pressure sending unit is a possibility, but I'd like to hear from anyone who's experienced this before.
Should I verify the pressure with a mechanical gauge first, or are there other common causes I should check? I really don't want to risk damaging the engine.
The OEM gauge is a crapshoot and likely isn't reading very accurate. I replaced my sending unit with a new OEM and the gauge still reads very low under the conditions you described.
Yes, use a quality aftermarket gauge to get an accurate reading. You can also open the oil cap and visually look for oil flinging around off the cams and out the HLAs. Keep a rag handy because it will probably make a mess.
Edit: here's a video showing what you can expect by removing the oil cap. Another video two posts down too.
Nice Cherokee-D upscale.
As mentioned the factory gauge and sender are known for their inaccurate presentation, not only on the 1G and 2G's but on other Mitsubishi cars like the 3000GT. There is a oil pressure warning light and if it's not flashing your most likely not have a low pressure issue but verifying the actual oil pressure with a mechanical gauge or a quality electronic one is a great idea.
FYI the various holes in the oil filter housing are 1/8 BPT (BSPT) tapped not the more common NPT. You'll likely need an adapter to connect an aftermarket gauge/sensor.
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
  • For sale OEM EVO 9 Injectors
    Selling a set of OEM pink top 560cc Evo 9 injectors. Had no issues with these and they have been...
    • tyvo98gsx
